SSD Help
Go to solution Solved by JeffreyEagan,
Soz to bother you again. But how to I delete the OS on the SSD currently as it was in my Laptop. So then I can install the OS on the Gaming PC.
When you go to install the new OS you can format the SSD and install the new OS over it.
just plug in the sata and format it from disc management (windows search)
but if it does have a OS make sure you go to bios to boot on your Gaming pc's OS and not the SSD's OS
Ok what do you mean gaming Pc's OS. The computers never had a hard drive or SSD in it before?
https://linustechtips.com/topic/427863-ssd-help/#findComment-5739335
https://linustechtips.com/topic/427863-ssd-help/#findComment-5739387
