Hyper 212 Evo in NZXT S340
dmtben
Hi, I'm looking to put a CM Hyper 212 Evo into an NZXT S340 on a MSI Z97 PC Mate motherboard with KIngston Hyper X Fury RAM. Can someone let me know if I will have RAM clearance issues or clearance issues with the side panel on the S340?
Has anyone actually put a 212 in the S340 and can tell me whether or not it actually fits?
Thanks
Thanks
That should all fit with ease m8! The 212 fits just about everything, the RAM is pretty low profile actually (no stupid heat sink fins etc...) and that case has loads of room for CPU coolers so should be good m8! Good luck with ur build and make sure u post it here if u can!
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
Thanks
It fits in the case. Don't think there'll be an issue with the ram. They aren't super high profile.
It fits good. I've seen completed builds over at PCPartPicker.com. I'm building one soon for a friend as well.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
I had a 212 in my s340 before I got my AIO cooler. You're all good!
