Does Molex Deteriate Through Length
Go to solution Solved by MrSuperb,
With 6 of those Swiftech Fans and an 8 meter long cable (AWG16) the voltage drop should be below 0.2 Volts.
(no responsibility is taken for the correctness of this information)
Hey everyone,
I was planning on having fans on a radiator long way away from my computer. Routing the fans through molex with a bitspower x-station, then they would be at least 5-8 metres away from that. Would the power deteriorate badly. If not how could I get it this far. But if so, would other ways could I achieve this?
Thanks
https://linustechtips.com/topic/42702-does-molex-deteriate-through-length/
It won't 'deteriorate' as such however you can get voltage drop across distance with cable. Unless you're undervolting, you won't have an issue.
Um that's exactly what I was going too do... Also how would I get a cable that long? Or just lots of extensions? Why would undervotlting cause an issue?
Fans can be damaged when undervolting.
I should have clarified - undervolting dramatically such as 5v. I haven't got any experience with voltage drop across DC current on 16-18AWG wire but I imagine it will be more dramatic than AC across 12AWG.
Cables - Bitfenix sell 1.5m 3 pin cables or you can make your own molex.
I thought lots of people undervolted their fans without an issue?
It doesn't damage them to a point where they won't work, it just decreases the lifespan of the fans.
so a 7v undervolt should be ok? Not sure what you mean by AWG.
Would a 7v under-volt reduce a lifespan dramatically. If so, how dramatically
By the time you get a new PC, they may start to fade out a little bit.
ok thanks
so like 2-3 years?
Probably a little more if you get good fans.
wait whaat? running the fans lower than 12v reduce their lifespan? Never heard of it before, i thought it was the other way around
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
It's still longer than the lifespan of the computer.
Mini-Desktop: NCASE M1 Build Log
Mini-Server: M350 Build Log
as in it will drop less than 0.2 volts or it will drop to less than 0.2 volts.
Thanks
wouldn't lots of extenders intoduce some kind of latency? Make my own? Where could I buy the stuff for that and how?
eBay - you need the crimp connectors, a crimping tool or pliers, 16AWG wire. MDPC also sell them; http://en.mdpc-x.com/mdpc-crimping.htm
