Best AIO?
Go to solution Solved by arronleeds,
Probably the kelvin s36 or the kraken x61.
What's one of the best AIOs for under $200?
The Brokish Boy v1: CPU: i7-8700k GPU: MSI Gaming X GTX ti MOBO: Asus ROG Maximus X Code Ram: G.Skill Trident Z 4x8gb 3200mhz DRIVES: 2x3TB WD Black , 500gb Samsung 850 EVO SSD, 500gb 970 EVO SSD Case: be quiet! Dark Base Pro 900 Black Headphone: ATH-MSR7 Mic: Blue Yeti Monitors: 27" BenQ GW2765 1440p; IPS, 27" Acer Predator XB271HU 1440p; VA
https://linustechtips.com/topic/426300-best-aio/
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/426300-best-aio/#findComment-5720134
It is more future proof..
So? "Future proof" means nothing unless he plans on switching to a full loop. There's plenty of things that qualify as more future proof, but it's not a reason to buy them when they perform badly.
He also asked specifically for an AIO, if he wanted a custom loop, he would have gone/asked for one. Custom loops also take up much more room and are much harder to just remove from the case when needed.
EDIT: There's also an increased chance of leaking, more maintenance, risks of breaking the PC when installing and filling, having to bleed and leak test the loop and so on.
https://linustechtips.com/topic/426300-best-aio/#findComment-5720156
and harder to install. its not like an AIO, just slap it in.
Ryzen 7 5800X3D , Arctic Liquid Freezer  III , Gigabyte X570 Aorus Elite , Corsair Vengeance 32GB , Gigabyte RTX 5070Ti ,  WD SN850 / MP44L
Corsair RM 850x, LIAN LI Lancool 207
https://linustechtips.com/topic/426300-best-aio/#findComment-5720175
