Is my CPU to Hot??
Hey Guys,
So at idle my cpu runs at 29-30C but when I was doing a prime95 AI Suite III was saying I have 75C and realtemp gave me these numbers 85, 80,75,70. I have not overclocked my CPU at all, I want to check that it was stable before I started and these tempuratures worried me.
CPU: i7 4770k Haswell
Cooler: H80i with two noctua NF-F12 fans
Could anyone let me know if this is anywhere normal and if I should do something something
Im still shocked at advanced users reply's.
your idle temp is perfect!
if all your parameters are set for "default" this means your cpu vcore is set for "adaptive"
both aida64 and prime95 increase your vcore when you use either of the two programs to stress test, unless you set your Vcore mode to Manual and manually input your stock cpu vcore votage, which is 1.150V
If you want to avoid any headaches Dont use prime95 or aida64 to stress test, prime95 is not even validated for the haswell platform right now.
use the IETU. it does not unnecessarily manipulate voltages! so you dont have to worry about your vcore mode and leave it set for "adaptive" which is best..
use the ietu to stress test and to monitor your voltages and temps.
stress test with the ietu and report back with your load temps.
