Had the same issue, don't really remember how I fixed it, it just suddenly worked. Reinstall drivers as said, make sure you get them off nvidia homepage and not through Windows Update. Try a reboot or two as well if you've got no luck after that.
i5-4690k | GALAX HoF 980Ti | MSI Z97 Gaming 3 | 2xHyperX Fury 8GB @ 2133MHz | 2x240GB Kingston SSD in RAID-0 | 500GB Samsung 850 EVO | NZXT H440 | Corsair H75 | Corsair RM750
Do not go gentle, into that good night.
Just uninstall the drivers with Display Driver Uninstaller and Download the latest drivers straight off from Nvidia web page and install it. It should work.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
First of all something no one here asked, did you do a clean install? You upgraded then in options reinstalled Windows 10 clean? AFTER you do that, install the latest drivers from Nvidia for Windows 10.  Hope this helps. :)
-Snip-
Also you can follow your thread by clicking the button "Follow this topic" on the top-right of this thread.
●CPU: i7-4790K w/H100i ●Mobo: MSI Z97 MPower ●RAM: Corsair 16GB Dominator ●GPU: EVGA ACX SC 780 3GB(X2) ●SSD: 850 Pro 256GB ●Case: 450D ●PSU: AX 860i ●Monitor: Asus PB278Q 1440p
