I was sitting down to play some Euro Truck Simulator 2, and figured that I should listen to a podcast while driving all across the European continent. I plugged my PC speakers into my phone to continue a podcast I had already started on there, without turning them off, then realized that I wasn't thinking, and wouldn't be able to hear the game sounds with the speakers unplugged - duh. I plugged the speakers back in to my computer, having never turned them off, mind you, and then it started: the buzzing noise.
This buzzing noise does not persist when the speakers are turned off or unplugged from any device, and if I plug in different speakers to the PC, everything is fine and dandy.The buzzing does, however,  appear if I plug the speakers into different device - my phone, my laptop, and an iPad, to be specific. The buzzing is independent from the computer, since I can adjust the volume through windows without making the buzzing louder, and vice versa.
Interestingly, If I rotate the 3.5mm connector that goes into the devices, or angle it slightly and in just the right orientation, the buzzing will go away and it will sound perfect.
I'm at a bit of a loss as to what could be causing the problem and wonder whether it could have something to do with the fact that I didn't turn off the speakers before unplugging them from my PC. At any rate, I hope that someone may be able shed some light on the problem and possibly a solution.
The speakers are Logitech z313's
._.
AMD A8-5500•••ASUS GTX 660•••MSI MS-7778 Mobo•••2x4GB DDR3 RAM•••CoolerMaster v550 Semi-Modular PSU•••1.5TB HDD•256GB Samsung 850 Evo SSD•••Optical Drive•••Phanteks Enthoo Pro
https://linustechtips.com/topic/423467-pc-speaker-buzzing-on-every-device/
Probably either a pin in the 3mm jack is loose, or there is a wire deformity/break within the cable itself. Shouldn't really be anything to worry about though, as long as there is a way to make the buzzing go away. If the speakers are individually plugged into the subwoofer, make those connections are firmly in, just in-case.
Speedtests
WiFi - 7ms, 22Mb down, 10Mb up
Ethernet - 6ms, 47.5Mb down, 9.7Mb up
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
 RAM             8GB CORSAIR XMS3 (2x4gb)
 Cooler          LC Power LC-CC-97 65W
 Motherboard     ASUS H81M-PLUS
 GPU             GeForce GTX 1060
 Storage         120GB Sandisk SSD (boot), 750GB Seagate 2.5" (storage), 500GB Seagate 2.5" SSHD (cache)
Type            Server
OS              Ubuntu 14.04 LTS
CPU             Core 2 Duo E6320
RAM             2GB Non-ECC
Motherboard     ASUS P5VD2-MX SE
Storage         RAID 1: 250GB WD Blue and Seagate Barracuda
Uses            Webserver, NAS, Mediaserver, Database Server
Quotes of Fame
On 8/27/2015 at 10:09 AM, Drixen said:
Linus is light years ahead a lot of other YouTubers, he isn't just an average YouTuber.. he's legitimately, legit.
On 10/11/2015 at 11:36 AM, Geralt said:
When something is worth doing, it's worth overdoing.
On 6/22/2016 at 10:05 AM, trag1c said:
It's completely blown out of proportion. Also if you're the least bit worried about data gathering then you should go live in a cave a 1000Km from the nearest establishment simply because every device and every entity gathers information these days. In the current era privacy is just fallacy and nothing more.
I'm hesitant to accept the conclusion that the jack is the problem, since other speakers work fine in it, and this problem arises on more than one machine. As for the wire deformity/break, well I was hoping that wasn't the problem since I'll have to replace them (though I just checked, they are under warranty until Christmas :D ).
The problem is that I can make the buzzing go away if I find the exact position of the connector which will fix it, but It is so delicate that a tiny shake in the desk will move it and ruin it - not ideal.
._.
I'm hesitant to accept the conclusion that the jack is the problem, since other speakers work fine in it, and this problem arises on more than one machine. As for the wire deformity/break, well I was hoping that wasn't the problem since I'll have to replace them (though I just checked, they are under warranty until Christmas biggrin.png ).
Might be worth it to get them replaced under warranty if you can then ^_^. If that's not ideal, then you could find the part where the wire is broken and reinforce it with tape
Speedtests
Rigs
 Type            Desktop
 OS              Windows 10 Pro
 CPU             i5-4430S
Type            Server
OS              Ubuntu 14.04 LTS
RAM             2GB Non-ECC
Quotes of Fame
