Hi i would like to know what exactly is the diference betwen fx 6300 and fx 6350 and ofc same goes for fx 8300, fx 8320, fx 8350 and fx 8370. Also what is the difference betwen 8370 and 8370E.
I did notice difference in clock speed, but is there any other difference than that and how different are their overclocks. My friend told me that all of those cpus are same architecture just factory overclocked 6300 and 8300 and if i go and oc with proper water cooler they will all overclock to same clock speeds (based on silicon lottery) and will perform the same (if 8320 and 8370 are oc to same clock speed they give identical perforance) therefor suggesting me to go with cheapest one *6300 or 8300
https://linustechtips.com/topic/423318-am3-cpu-difference-dilemma/
FX 6350 is an overclocked FX 6300 - same for 8320 and 8350 and 8370.
EDIT: That means a guaranteed overclock = no silicone lottery - you also don't need water cooling, simple air cooling is fine.
Clock speeds are the difference. You might be able to get a higher overclock by going with a 6350 vs a 6300 for example - it's binned higher. The difference between the 8370 and 8370E is clock speed and voltage. The 8370E runs at 3.3GHz versus 4GHz and at a lower voltage, thus having lower heat output and power consumption.
The only difference between the FX-6300 and 6350 is the default settings (the extra 0.5GHz core frequency). Same idea with all the FX-8 chips. In fact all the FX-6 chips are the same as the FX-8 except with 2 cores disabled.
In other words, your friend is right.
Were they? I thought the 6100 and 6300 were different chips. Same for 8150 and 8350
Within the same architecture, they are the same. You are correct about the 8150 and 8350 being different, along with the 6300 and 6100. The 83xx and 63xx CPUs use Vishera while 61xx and 81xx use Bulldozer. Same applies to the 4 core variants as well.
Oh right, the FX refresh, right? I guess I remembered correctly :D
FX-6300 and FX-6350 just does not have same clock speed.
FX-8320 & FX-8350 is same story.
FX-8370 uses less power than FX-8350 and is clocked higher and has a better chance to reach better OC. (it currently holds world record and beat FX-9370 & FX-9590)
FX-8320E & FX-8370E uses less power but is clocked lower... (for low end boards)
Best value for most is FX-6300, FX-8320 or FX-8350. (but its lottery!)
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
8370 and 8350 have the same base clock, but the 8370 has a higher turbo by 0.1GHz.
FX-8370 uses less power than FX-8350 and is clocked higher.
You need to be more specific. The base frequencies are the same, but the turbos are different. It's not inherently clocked higher - it depends on the situation.
Yes but still higher! :P
Those are different, I was only talking about within the 63xx and 83xx generations. I didn't think anyone still talked about 61xx and 81xx lol.
They don't maintain the boost clock all the time-so they still aren't clocked higher only boosting higher. For example, my i5 4440 is sold as being 3.3GHz, when in reality it rarely maintains that frequency for more than a few seconds and mostly stays at the stock speed of 3.1GHz.
           .;ldkO0000Okdl;.                michael@SUSE-BlackBox
        .;d00xl:^''''''^:ok00d;.            OS: openSUSE 20260405
      .d00l'                'o00d.          Kernel: x86_64 Linux 6.19.11-1-default
    .d0K^'  Okxoc;:,.          ^O0d.        Uptime: 2d 21h 52m
   .OVVAK0kOKKKKKKKKKKOxo:,      lKO.       Packages: 6556
  ,0VVAKKKKKKKKKKKKK0P^,,,^dx:    ;00,      Shell: bash 5.3.9
 .OVVAKKKKKKKKKKKKKk'.oOPPb.'0k.   cKO.     Resolution: 3840x1080
 :KVAKKKKKKKKKKKKKK: kKx..dd lKd   'OK:     DE: KDE
 lKlKKKKKKKKKOx0KKKd ^0KKKO' kKKc   lKl     WM: KWin
 lKlKKKKKKKKKK;.;oOKx,..^..;kKKK0.  lKl     GTK Theme: Breeze-Dark [GTK2], Breeze [GTK3]
 :KAlKKKKKKKKK0o;...^cdxxOK0O/^^'  .0K:     Icon Theme: breeze-dark
  kKAVKKKKKKKKKKKK0x;,,......,;od  lKP      Disk: 13T / 22T (60%)
  '0KAVKKKKKKKKKKKKKKKKKK00KKOo^  c00'      CPU: AMD Ryzen 7 5800X3D 8-Core @ 16x 4.55295GHz
   'kKAVOxddxkOO00000Okxoc;''   .dKV'       GPU: AMD Radeon RX 6700 XT (radeonsi, navi22, ACO, DRM 3.64, 6.19.11-1-default)
     l0Ko.                    .c00l'        RAM: 13127MiB / 48094MiB
      'l0Kk:.              .;xK0l'
         'lkK0xc;:,,,,:;odO0kl'
             '^:ldxkkkkxdl:^'
It's being sold as having a base clock of 3.1GHz and a boost clock of 3.3GHz which is in line with your experience and the advertisement.
When I bought my computer (as in I had it built), the i5 was listed as being 3.3GHz. Only by actually monitoring the frequency was I able to see that it was only boosting to 3.3GHz for a short while (I'd never owned a CPU that could boost beforehand).
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
Well, it's not like that now.
http://ark.intel.com/products/75038/Intel-Core-i5-4440-Processor-6M-Cache-up-to-3_30-GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116942
Ok i do understand so basicly go with cheapest 63xx and 83xx and hope for the good oc or pick 8370 *that cost around 50% more where i live.
Going with a higher clocked chip increases your chances of getting a better chip for overclocking - it still doesn't guarantee anything.
I know that Intel list it as being 3.1Ghz, but the computer shop I bought it from sold the i5 as being 3.3Ghz-I was ignorant of its actual specs as the last desktop CPU I'd used had been a Pentium III.
      'l0Kk:.              .;xK0l'
             '^:ldxkkkkxdl:^'
no, just get an i5-4460 and a cheap H series or B85 motherboard that will bitch slap the old FX in just about anything and you'll save by not having to buy an 8 phase motherboard and an aftermarket CPU cooling solution...you also get modern features such as PCIe 3.0 namely and you'll save on heat and power bills too.
The FX-83XX makes no sense what so ever these days unless you're building a cheap rendering farm.
Look, cheap intel kit vs cheapest possible kit that would work for overclocking the AMD FX, it cost the same:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($166.95 @ SuperBiiz)
Motherboard: Gigabyte GA-B85M-GAMING 3 Micro ATX LGA1150 Motherboard  ($41.98 @ Newegg)
Total: $208.93
Generated by PCPartPicker 2015-08-04 22:09 EDT-0400
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($139.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($26.99 @ NCIX US)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard  ($82.89 @ OutletPC)
Total: $249.87
Generated by PCPartPicker 2015-08-04 22:10 EDT-0400
The intel is even cheaper mind you!
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
FX 41xx, 61xx and 81xx series is the ORIGINAL bulldozer chips
FX 43xx, 63xx, 83xx and 9xxx is PILEDRIVER chips, they have higher IPC, bette scheduling and in general, clock for clock, better performance then bulldozer.
FX 8320e and 8370e is super binned chips. They are designated as upgrade paths for people with a FX 4xxx and 6xxx CPU on a lower end AM3+ board can upgrade without issues
FX8320e and 8370e is more likely to OC high then other chips as they are highly binned in order to maintain a little lower clock speeds then the normal chips, but at severely reduced voltages. This causes them to use 30w less... which is HUGE.
Just because they can maintain lower clocks at much lower voltages doesn't mean they'll overclock super well. I don't even think the chances increase at all of getting a good chip.
I cannot guarantee that they will all reach 5GHz, but you do not find a chip, designed to run at 125w, that can run at 95w with only 300MHz reduction to NOT be a highly binned example.
For reference, Anandtech has gotten their 8320e to 4.8Ghz, while ONE chip isnt a indicator on how well ALL are going to OC, it is still a indicator of what the "E" chip CAN reach.
