I just built a PC and I ran a stress test on AIDA64 just to see if my temps were good even though I had a i3
During the test which I only ran for around 20 minutes my CPU hit a maximum of 94C and was hovering between 78-87C during most of the test which isn't good for a non OC CPU even if it's a Stock cooler
My GPU which I was hoping to overclock was around low 80s
Is this cause for concern? Did I incorrectly mount the cooler so that the thermal paste is working?
Should I not consider overclocking the GPU or should I not use this test?
Also my CPU didn't throttle during the test
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/422613-high-temps-in-aida64/
check your thermal paste
you should be getting at most 80 degrees under load
if your GPU is around 80 degrees under load then you probably shouldnt overclock it
also check your fan setups. maybe there isnt any airflow in the case?
I thought it was probably the thermal paste
My case is a NZXT S340 with 2 exhausts and 2 intakes so I don't think airflow is a problem and I'm running a Sapphire 380 which is supposed to be really good
        Setup
https://linustechtips.com/topic/422613-high-temps-in-aida64/#findComment-5675039
Right now my CPU is idling around 48C which is normal and the GPU is 56C which I think is normal as well.
        Setup
https://linustechtips.com/topic/422613-high-temps-in-aida64/#findComment-5675053
my gpu runs around 30 degrees when idle
but mine is nvidia so i dont know much about amd cards
do some research to see the typical temperatures for your chips
https://linustechtips.com/topic/422613-high-temps-in-aida64/#findComment-5675061
my i5 with 212 evo idles in the 30`s and my strix 970 idles in the 30`s also and im in a h440
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/422613-high-temps-in-aida64/#findComment-5675105
