Building a PC but not really sure if everything will work fine my Budget is about 400GBP
Solved by JefferyD90,
Thx man for fast answer and sorry for not quoting you im new to this forum so i didnt understand how to reply, but never mind could you give me a hand because as i said im not good with building pc´s and as i stated before any help is welcome
and im still having only a budget of 400 GBP
The build you put together isn't terrible, I just personally think its quite a bit lop-sided and I generally don't like buying things used and such.
I obviously know you cant buy the parts from the link I provided, but you can look around on the etailer of your choice for the models I have listed.
