Low FPS. Help, please!
Go to solution Solved by manikyath,
moral of the story: dont buy lenovo? #senselessHate
This is for my best buddy :) He told me to post this :D
So, I got a new all in one which is one of the Lenovo C series, but it runs games worse than my laptop which is lower spec than this PC!! All drivers are up to date on both PCs... Here are the specs (THERE IS NO DEDICATED GRAPHICS CARD!)
New PC (Lenovo):
Intel Celeron J1800 @ 2.41 Ghz
4.00GB RAM
Windows 8.1
DX Version- 11
Intel HD Graphics with 1792MB memory
Old Laptop (Acer):
Intel Core i3-2310m @ 2.10Ghz
4.00GB RAM (2GB Stick Failed)
1760MB Graphics Memory (Intel HD Graphics 3000
Windows 10 Home
DX Version- 11
Any help is appreciated! Thank you!
System Specs
  • Gaming/work PC:
    • Processor: Intel Core i7 4790k  @ 4.5Ghz
    • Memory: 32GB RAM (Corsair Vengeance)
    • Graphics: ASUS GTX 980 Ti
    • Motherboard: Gigabyte Gaming 5 Z97
    • Storage: 3x 1TB Samsung SSDs (Not in RAID) & 1TB WD Black HDD
    • Case: H440 Designed By Razer
https://linustechtips.com/topic/422453-low-fps-help-please/
New PC (Lenovo):
4.00GB RAM
Windows 8.1
DX Version- 11
Old Laptop (Acer):
Windows 10 Home
DX Version- 11
an i3 has 2 more cores than current celerons correct???
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/422453-low-fps-help-please/#findComment-5672984
Well he shouldn't expect to run games on intel integrated graphics on a celeron.
FX-6300 cooled by Nepton 240M | EVGA GTX 970 SuperClocked | 8GB G.Skill ValueRAM | Cooler Master 690 III | Sharkoon WMP 500 Bronze
Power supplies:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ My F@h stats: http://fah-web.stanford.edu/cgi-bin/main.py?qtype=userpage&username=zyntaxable Intel vs. FX for gaming: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
https://linustechtips.com/topic/422453-low-fps-help-please/#findComment-5672989
celeron.... jesus christ
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/422453-low-fps-help-please/#findComment-5673004
Okayy! Thanks for the replies! My friend is crapping himself with this right now. But on the i3 he can get good frames but there is a like 3 second pause or stutter... anything on this guys?
System Specs
  • Gaming/work PC:
https://linustechtips.com/topic/422453-low-fps-help-please/#findComment-5673036
Haha :) They did make a good High End gaming PC though. Still better to build it yourself! :D
System Specs
  • Gaming/work PC:
https://linustechtips.com/topic/422453-low-fps-help-please/#findComment-5673044
2 more threads, not cores.
Very true! But will the extra 0.31 Ghz not make a difference?
System Specs
  • Gaming/work PC:
https://linustechtips.com/topic/422453-low-fps-help-please/#findComment-5673070
Not really, the extra threads even if they are not physical still help on leveraging the load.
The main problem is that there is no GPU, the iGPU is not powerfull by itself, that's another reason he was getting more frames on his old laptop.
Also, why didn't he ask for help when he was going to buy it?
https://linustechtips.com/topic/422453-low-fps-help-please/#findComment-5673089
if lenovo didnt go potato on their power supply you *could* perhaps toss a GTX750ti in there...
that is, if they didnt pull an HP and "saved cost" on a PCIe slot.
Of all the lenovo PCs I have ever had. Not any one had a PSU. And Plus, my buddys PC is an All in One :P
System Specs
  • Gaming/work PC:
https://linustechtips.com/topic/422453-low-fps-help-please/#findComment-5673090
You can always get another power supply for the laptop you know, also having a single PCIe slot is not the end of the world, he could just work with ethernet instead of wifi while at home. It may not be the ideal senario but it's manageable even if a bit tedious.
https://linustechtips.com/topic/422453-low-fps-help-please/#findComment-5673101
He does not trust Forums ;-; I told this one is the best one out there though ;-; He wanted me to do it instead. He had some bad experiences with them that involved me fixing his PC ;)
System Specs
  • Gaming/work PC:
https://linustechtips.com/topic/422453-low-fps-help-please/#findComment-5673106
That's like saying I don't trust gas stations because they have expensive and bad quality gasoline. xD
https://linustechtips.com/topic/422453-low-fps-help-please/#findComment-5673122
