My commputer is a light sleeper
Solved by Jiia,
Go to Device Manager and open up the settings for your mouse. Go to the "Power Management" tab and turn off the setting "Allow this device to wake the computer". This way your mouse won't wake up your computer at all.
If that doesn't work you can manually turn it off by opening up a command line and typing
1. "powercfg -devicequery wake_armed"
2. This will list all devices that can wake up the computer. Find your mouse in the list.
3. "powercfg -devicedisablewake 'name_of_the_mouse_as it appeared_in_the_list' " (include the single quotes)
