1. Budget & Location
My budget is not really limited to an amount but this system will only be used for cs:go as I use my MacBook for studying/web browsing and my PS4 for most of my gaming needs. So I would like this system to be the cheapest it can be but still be able to run cs:go at 200-250 fps on 1024x768 with a 144hz monitor. As this is a quite low resolution I think this will be achievable with a relatively small budget.
I live in the Netherlands.
3. Monitors
I am currently using a basic 1080p 60hz monitor but I would like to upgrade to a 144hz one, I was thinking about getting a Korean monitor as these have a great performance for their price. I will only be using 1 monitor.
4. Peripherals
I already have all my peripherals, CM storm Alcor, Steelseries QCK+, Corsair Vengeance K65.
5. Why are you upgrading?
I am upgrading because the system I am currently using to play cs:go just doesn't have the performance I want, a 8 year old pc with a q9300 and a gt730, was only 20$ so I thought why not. Although this sounds extremely old and slow I was still able to achieve about 100-130 fps which was astonishing to me as this PC was 8 years old and only the gpu was ever upgraded and only for 20$!
https://linustechtips.com/topic/421111-build-solely-for-csgo/
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($194.89 @ OutletPC)
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler  ($34.90 @ Newegg)
Motherboard: Gigabyte GA-H97-D3H ATX LGA1150 Motherboard  ($88.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory  ($46.99 @ Newegg)
Storage: Crucial BX100 120GB 2.5" Solid State Drive  ($59.99 @ SuperBiiz)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: Gigabyte Radeon R9 380 4GB SOC Video Card  ($229.99 @ Amazon)
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case  ($89.99 @ Newegg)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($68.99 @ SuperBiiz)
Total: $861.62 or 782.92 EURO
Generated by PCPartPicker 2015-08-01 18:59 EDT-0400
BigDay
https://linustechtips.com/topic/421111-build-solely-for-csgo/#findComment-5656650
-Snip-
I'm just going to say, lay focus on a good processor. Get an i5 and maybe overclock it a little for max performance. Get a 960 or an AMD equivalent IMO, should be way more then enough.
But especially.
You give us location.
Use of system.
Info bout peripherals.
Budget.
Thanks for being considerate for the people that help.
Welcome to the forums!
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/421111-build-solely-for-csgo/#findComment-5656688
thats REALLY overkill for CS:GO an i3 and a 760 is more than enough
https://linustechtips.com/topic/421111-build-solely-for-csgo/#findComment-5656705
if you want to save some more money, consider this build:
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor  ($102.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1600 Memory  ($43.99 @ SuperBiiz)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($44.99 @ Micro Center)
Video Card: Gigabyte Radeon R7 370 2GB WINDFORCE 2X Video Card  ($149.99 @ Amazon)
Case: Corsair 200R ATX Mid Tower Case  ($59.99 @ NCIX US)
Total: $606.82 or 551.15 EURO
Generated by PCPartPicker 2015-08-01 19:12 EDT-0400
OR THIS, with a less expensive motherboard:
Motherboard: MSI H97M-E35 Micro ATX LGA1150 Motherboard  ($65.98 @ Newegg)
Total: $583.81 or 530.43 EURO
Generated by PCPartPicker 2015-08-01 19:13 EDT-0400
BigDay
https://linustechtips.com/topic/421111-build-solely-for-csgo/#findComment-5656740
for csgo at that resolution this should be plenty
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($45.89 @ OutletPC)
Video Card: MSI Radeon R7 360 2GB Video Card  ($108.99 @ SuperBiiz)
Case: Cooler Master N300 ATX Mid Tower Case  ($49.99 @ Newegg)
Total: $390.84
Generated by PCPartPicker 2015-08-01 19:19 EDT-0400
System: CPU - I5-6500 Motherboard - Asus B150M-A RAM - Crucial ballistix sport 2x4GB DDR4 @2400MHz GPU - RX 480 PSU - Seasonic S12II 520W Case - Aerocool Aero-800 HDD - Seagate 1TB SSD - PNY CS1311 120GB Monitor - AOC G2260VWQ6
https://linustechtips.com/topic/421111-build-solely-for-csgo/#findComment-5656788
