Need help
Go to solution Solved by ciprian97pop,
there's a bios flashback and I pressed it, now it won't even boot
umm... don't know about that. that's mostly used for unsuccesfull bios updates
i'm going to find your motherboard manual to see some things
http://dlcdnet.asus.com/pub/ASUS/mb/SocketAM3+/SABERTOOTH_990FX_R2.0/E8042_SABERTOOTH_990FX_R2.pdf
page 1-26 from "to erase RTC Ram"
any follow up??
So I'm ocing my fx 8350 I changed stuff like the voltage to 1.4v and the cpu ratio to 23 (to get 4.6ghz) when I went to save the settings and restarted it but now it can't boot. What's wrong? It would turn on then turn off in a couple of seconds and nothing shows up on the screen
The Brokish Boy v1: CPU: i7-8700k GPU: MSI Gaming X GTX ti MOBO: Asus ROG Maximus X Code Ram: G.Skill Trident Z 4x8gb 3200mhz DRIVES: 2x3TB WD Black , 500gb Samsung 850 EVO SSD, 500gb 970 EVO SSD Case: be quiet! Dark Base Pro 900 Black Headphone: ATH-MSR7 Mic: Blue Yeti Monitors: 27" BenQ GW2765 1440p; IPS, 27" Acer Predator XB271HU 1440p; VA
https://linustechtips.com/topic/421098-need-help/
Probably too high clock.
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/421098-need-help/#findComment-5656420
how do I change it? I can't even get into the bios? I'm using the asus sabertooth 990fx r2.0
https://linustechtips.com/topic/421098-need-help/#findComment-5656454
You need to reset the BIOS in the clear CMOS jumper.
https://linustechtips.com/topic/421098-need-help/#findComment-5656466
If doesn't even turn on,try taking out the battery and putting it back in
Or this (I have a very old motherboard without pretty buttons...)
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
https://linustechtips.com/topic/421098-need-help/#findComment-5656468
how do I do that?
https://linustechtips.com/topic/421098-need-help/#findComment-5656481
how do I do that?
http://www.techarp.com/review/DFI/LANParty_UT_NF4_SLI-DR/cmos_jumper.jpg
http://panam.gateway.com/s/MOTHERBD/shared/4006200R/4006200R_20.JPG
You need to change the position of this jumper for like 5 seconds, and put it back to the other position again, its labeled as CLR_CMOS or CCMOS
http://i.ytimg.com/vi/rdHH9KrceR0/maxresdefault.jpg
Some new mobos also have a button, that is easier to use, you just need to press it.
https://linustechtips.com/topic/421098-need-help/#findComment-5656519
how do I do that?
find your motherboard manual and see if you have a reser cmos button. if you don't have one open your pc and look on the motherboard for something that looks like a watch battery
it should look something like this
take out the battery, wait for like 10 seconds then put it back in. your bios should be reset
Don't know if I have to say it but, do this with the pc unplugged from the wall
edit:
here's a guide from asus
http://support.asus.com/Troubleshooting/detail.aspx?SLanguage=en&p=1&m=SABERTOOTH%20990FX%20R2.0&s=24&hashedid=n/a&os=&no=1723
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
https://linustechtips.com/topic/421098-need-help/#findComment-5656542
https://linustechtips.com/topic/421098-need-help/#findComment-5656564
any follow up??
https://linustechtips.com/topic/421098-need-help/#findComment-5656584
umm... don't know about that. that's mostly used for unsuccesfull bios updatesi'm going to find your motherboard manual to see some things http://dlcdnet.asus.com/pub/ASUS/mb/SocketAM3+/SABERTOOTH_990FX_R2.0/E8042_SABERTOOTH_990FX_R2.pdfpage 1-26 from "to erase RTC Ram" any follow up??
it booted and had to setup bios again
https://linustechtips.com/topic/421098-need-help/#findComment-5657311
Glad it worked ^^
https://linustechtips.com/topic/421098-need-help/#findComment-5670230
