Case Fans
Go to solution Solved by Aytex,
why not buy the gaming 5?
your mobo will ahve 3 or 4 little silver pins sticking out. you connect them to thoues
948aa8db2103c839da381370cd4d94c2.pngthers probley more idk
the cpu cooler one should be pluged into the sys-fan
the case fan's dont matter where thoes are plugged in
cpu cooler should be plugged into the one with pmw or 4 pins, normally only cpu_1 will have true pmw with opt going off it. System fans are normally 3 pin and go off voltage, 5, 7 and 12 volts and sometimes go off the case temp not cpu temp as with gigabyte for some reason.
https://linustechtips.com/topic/420679-case-fans/#findComment-5651876
