After many research and a lot of time spent on choosing parts, this is the build I came out with (that best for my budget).
What are your thoughts?
Also a big thanks for all the people who help a noob like me in this forum I appreciate it a lot
1. Motherborad - Asus B85M-G
2. CPU - Intel Core i5-4590
4. GPU - AMD R9 390 Sapphire
5. Case - Corsair Carbide Series 200R
6. CPU Cooler - Cooler Master Hyper 212 EVO
7. SSD - Samsung 850 EVO 120GB
8. Crucial Ballistix  2x4gb ddr 1600
9. HDD - WG 1TB BLUE
10.PSU - SeaSonic 620W 80+ Bronze M12II EVO
https://linustechtips.com/topic/420248-my-first-computer-build/
Change the motherboard to a H97 one, get a 4460, change the PSU to the 520w version and try to get a 390X
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
https://linustechtips.com/topic/420248-my-first-computer-build/#findComment-5646953
looks amazing but try to colormatch
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/420248-my-first-computer-build/#findComment-5646955
H97 is completely unnecessary, waste of money. H81 will do just fine. Literally all you lose is the ability to have on board RAID. Why get a 4460, a downgrade? Currently in most places the prices are extremely similar, so you may as well get the better one. Getting a more expensive mobo will not allow a 390X to fit into the budget...
https://linustechtips.com/topic/420248-my-first-computer-build/#findComment-5646965
Nice build,
I see nothing wrong with it
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
https://linustechtips.com/topic/420248-my-first-computer-build/#findComment-5646985
Most H97 mobo's aren't that more expensive than B85 mobo's, so why don't get the better one? And downgrade to a 4460 so you can get a 390x
Project Pluto
https://linustechtips.com/topic/420248-my-first-computer-build/#findComment-5646996
Looks good, I would recommend getting a H97 motherboard, But it isnt required.
My Gaming PC
|| CPU: Intel i5 4690@4.3Ghz || GPU: Dual ASUS gtx 1080 Strix. || RAM: 16gb (4x4gb) Kingston HyperX Genesis 1600Mhz. || Motherboard: MSI Z97S Krait edition. || OS: Win10 Pro
________________________________________________________________
Trust me, Im an Engineer
https://linustechtips.com/topic/420248-my-first-computer-build/#findComment-5646997
You realise a 4590 is currently $13 more than a 4460 (just going off US for ease). An H97 mobo would probably mostly cancel out that price difference. A 390X costs over $100 more than a 390 (cheapest of each, according to pcpartpicker)
https://linustechtips.com/topic/420248-my-first-computer-build/#findComment-5647090
Ah, I'm not really familiar with USA pricing
Project Pluto
https://linustechtips.com/topic/420248-my-first-computer-build/#findComment-5647125
