How to get description thing under posts?
Go to solution Solved by Gale,
Go to your profile. You will see a blue button near the top that says "Edit my profile". Click it, then click on "Signature" on the left side, and type what you want there. Just make sure to follow the rules ( http://linustechtips.com/main/topic/95599-linus-tech-tips-forum-code-of-conduct/ [section 5] ).
Most people type something funny into their location.
Edit: You probably meant signature.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
thanks, best answer
