Need help trying to figure out a problem on windows 10
Solved by ThE_MarD,
Heyyo,that didnt help
Hmm... dunno what to say man, the only other thing to try is to get your product key and reinstall Windows 10 from scratch. Maybe the upgrade is corrupt?
https://www.magicaljellybean.com/keyfinder/
Use that, save your product key. Without it? Reinstalling will be an issue as you won't have a legit product key and windows 10 will start a 30 day timer until the copy expires.
What I do? Save it as a text file on services like Google Drive or Microsoft's OneDrive.
Then? Use this to download Windows 10 and make a DVD or USB drive as your Windows 10 Installer.
