For the past 6 month since after I rebuild my computer after changing the graphics and cooling for my computer. every time I turn on the computer from a cold boot it will turn on and pause at the screen where it starts to load windows. it stays like this for about 3 minutes then turns off.
when I then turn the computer on after that it will boot perfectly and on takes about <1 minute to load windows and will work fine after that.
some times when I turn it off after that it will turn on fine and some times it will do the same thing again or it may go into windows recovery.
note:  I think it may have to do with the hard drive being place into different sata ports. since originally installed win8
i have tried resetting the bios but that has not helped
Pc specs:
cpu: amd fx9590
motherboard: asrock 990FX Extreme9
gpu: amd r9 295x2
240gb ssd 320gb hard drive 500gb hard drive 4000gb hard drive
blue ray player
parts that where replace
navidia msi geforce gt630
any other details feel free to ask
https://linustechtips.com/topic/418463-system-re-booting/
Make sure windows isn't corrupted, and no updates are happening.
Edited by Godlygamer23
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/418463-system-re-booting/#findComment-5625728
Moved to Troubleshooting. In the future, make sure you post in the proper sub-forum. Furthermore, posting in the improper sub-forum to get more attention is not allowed.(Not saying this is the case, but for future reference)
https://linustechtips.com/topic/418463-system-re-booting/#findComment-5626242
  • 2 weeks later...
