Firefox.
D:
Anyway, until Edge gets extensions, you're better off with Chrome.
Firefox ;-)
haha I don't know, edge does intruige me but I would keep using Chrome as your primary and test out edge periodically to see how it develops; if you find yourself attracted to edge then you can always decide to switch.
 CPU:  Intel i7-4790K      Cooler:  Noctua NH-D14     GPU: ZOTAC GTX 1070 TI MINI     Motherboard:  ASUS Z97 Gryphon     RAM:  32GB G Skill Trident X
Storage: 2x 512GB Samsung 850 EVO (RAID 0) / 2TB Seagate Barracuda     PSU: 850W EVGA SuperNova G2     Case: Fractal Design Node 804
Chrome
extension support, unified account that saves my dataz
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
I would choose Edge, but currently can't change the search provider, install extensions like AdBlock, or rename my bookmarks with no name.  If they were fixed then I'd likely move to Edge over Chrome.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
