Hello PC enthusiast community,
     Hey guys i hope you are having a better day today then i am, this has been going on for the past 2 weeks now and i can't seem to figure out why my GPU is throttling itself back. I have had my pc for a little over a year now with no problems, and all parts are still under warranty. I'm getting massive core spikes every 3-5 seconds and it is unplayable. I started noticing the problem when i was getting heavy fps drops, so i turned on afterburner and noticed that my GPU was reaching temps up to 105 deg Celsius. which is really high. So i RMA my GPU (they gave me brand new GPU ) and put it in there and still the problem persists. The thing is i don't have extra parts to swap out to test what the problem is. I knew enough that i needed to find out if the problem is hardware or software so i re-installed OS with the CD, problem is still there. Its not the power supply i borrowed my brothers CX 600 , problem still there. im getting dips down to 40's when i should be getting 90-120 fps on low settings. At this point i don't know what to do and it can be very frustrating. I think i narrowed it down to either the CPU or the mobo. Any suggestions or input would be greatly appreciated, and thank you in advanced.
        Your fellow PC enthusiast, MyCampGround
PC build:
Wind 8.1 64bit
MSI A78M-E35
AMD athlon x4 760k
R7 260x 2GB OC
Crusial Ballistic Sport 1x8 ddr3 1600
West Digital Blue 1tb 7200rpm
corsair cx430
https://linustechtips.com/topic/417718-how-to-diagnose-problem/
Check your airflow in your case
The Brokish Boy v1: CPU: i7-8700k GPU: MSI Gaming X GTX ti MOBO: Asus ROG Maximus X Code Ram: G.Skill Trident Z 4x8gb 3200mhz DRIVES: 2x3TB WD Black , 500gb Samsung 850 EVO SSD, 500gb 970 EVO SSD Case: be quiet! Dark Base Pro 900 Black Headphone: ATH-MSR7 Mic: Blue Yeti Monitors: 27" BenQ GW2765 1440p; IPS, 27" Acer Predator XB271HU 1440p; VA
https://linustechtips.com/topic/417718-how-to-diagnose-problem/#findComment-5617451
running bf4 im experiencing lower fps than i should be actually getting around 40 fps dips when i should be getting 100 fps on low
Where are you seeing this 90-100 FPS result?
You need to look at what CPU you are comparing to -- multiplayer BF4 is much more CPU dependent.
If you are looking at a system with a i7-4790K with a R7-260X...it is going to be a HUGE difference versus your 760K and R7-260X.
Additionally, what version graphics card drivers are you using?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/417718-how-to-diagnose-problem/#findComment-5619989
