Difference between these two 970s?
Go to solution Solved by Aniallation,
Is there any difference between this and this, besides their color? I'm building in a green case where the fans would be visible (it's rotated) so color matching would be nice. I use the 4G (red) personally but if there's no other difference I'd rather go for green. I don't really want to use the "Linus Plasti-Dip" method.
The green one has a backplate, which looks nicer in your rig as you'll mostly be seeing the bottom of the card.
Red:
Green:
Thanks,
-Chris
https://linustechtips.com/topic/417408-difference-between-these-two-970s/
Thanks,
-Chris
yes clockspeeds
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
the green one possibly ocs better, but dont ask, i think the golden edition is the best one.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
Thanks,
-Chris
the green one in oc mode turbos farther thats all
Red:
Green:
"Rawr XD"
the clockspeeds are identical according to the product page...
There is no difference other than colour and backplate
i read into it tho and if you use msi gaming app the green one can turbo slightly farther
Red:
Green:
Thanks, though the case actually rotates the mobo so I'll be seeing the green fans instead
it sounds weird when you say farther xD, we use further.
