which is better? which cooler is better? Cooler Master Hyper 212 EVO or Noctua NH-L9I
Solved by tomas710,
whats the overclocking chip? how can i buy a better one?
i also own a asus hero motherboard, would that help with overclocking?
It's luck, some chips overclock better, the hero is a good mobo, that part should be fine, but right away, 4.6 is a BIG maybe, you may get 4.4, depends if you got lucky with the CPU you got, just how it works, more than 4.6 on a hyper 212 evo is almost impossible, and 4.6 is unlikely. I had a CM Seidon 120V and that let me overclock to 4.5, now i got a better cooler and i can get 4,7. But you gotta lower your expectations, 4.8 ain't happening, 4.6 if you're really lucky.
