He guys i acutally have a cd and I've been told that it will work only once, even if it stops in the middle of the installation!!! so can you tell me a way in which i can remove the copy rights and can use it several times??
NOTE:- It is not any software cd or any important cd. i have been given the cd from my tutorials, so i just wanted to use in more than 1 pc
https://linustechtips.com/topic/416606-copyright-issue/
could you be more specific what kond of CD that is?
why don't you ask the person that gave you this misterious CD?
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/416606-copyright-issue/#findComment-5603025
What kind of woo-woo is that? Is this Mission Impossible or something?
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
https://linustechtips.com/topic/416606-copyright-issue/#findComment-5603073
It must have something like time based trial. And those will start after you have installed whatever it is. We can't help you breaking any copyrighted material. Its against forum Code of Conduct.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/416606-copyright-issue/#findComment-5611264
2 things.
1. we can't because it's the software that locks it, not the copyright
2. we aren't allowed to help you with this because it can be seen as an illegal action, which is forbidden on this forum.
May the light have your back and your ISO low.
https://linustechtips.com/topic/416606-copyright-issue/#findComment-5611280
