Need advise on home network setup
Solved by mrenusso,
You say you have a slow internet connection, yet you didn't tell us what your broadband speed is. It may simply be slow because you have too many devices connected to the internet at the same time and your internet speed is just used at its maximum. You would have to upgrade your LAN equipment only if you were experiencing slow speeds on your LAN. Might just be time for a plan upgrade, not a modem/router/access point upgrade.
EDIT : grammar
