First Gaming Build
Go to solution Solved by grayblizzard,
This is my first build ever actually and I want to make a gaming PC that can run current-gen games on medium-high settings at around 60 FPS. This is my current list http://pcpartpicker.com/p/HnDfLk
this instead:
http://pcpartpicker.com/p/MBM2D3
this instead:
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/416027-first-gaming-build/#findComment-5595582
should work fine for your needs.
get a r9 380
and if you can spend a little more to get an i5 and an SSD would be awesome for you
"Well, not even last night's storm could wake you. I heard them say we've reached Morrowind, I'm sure they'll let us go."
https://linustechtips.com/topic/416027-first-gaming-build/#findComment-5595601
The B85 can't run the cpu since it's haswell refresh without a bios update.
I've had no problems, but it's easy to check before purchase and certainly worth the look.  Also if the bios is old then it can be updated, or alternatively just get the H81, the only real difference is front USB3 header.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/416027-first-gaming-build/#findComment-5596730
