Whats the difference between IPS and LED monitors?
If I get a 2ms LED monitor from benq, will it be worse than a IPS with a 5ms response time?
Thanks
EDIT:
Im either gonna get this IPS from asus or this LED from Benq.
Or if there are better ones please suggest them!
I have a budget of around 170 euros
                                         Cold
https://linustechtips.com/topic/415457-ips-vs-led-monitors/
IPS is better color reproduction
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/415457-ips-vs-led-monitors/#findComment-5588692
Ips have better colors and contrasts led can go low when it comes to response time and high when it comes to refresh rate tho 3ms are basically nothing
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/415457-ips-vs-led-monitors/#findComment-5588693
What two monitors are you looking at? 5 and 2ms response time is all a scheme to get you buy it there really isn't a big bidder ends.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/415457-ips-vs-led-monitors/#findComment-5588694
Thought that to, When they say LED they usually refer to LCD Screens that are LED back light
https://linustechtips.com/topic/415457-ips-vs-led-monitors/#findComment-5588700
Edited the post.
                                         Cold
https://linustechtips.com/topic/415457-ips-vs-led-monitors/#findComment-5588710
Thanks
EDIT:
IPS has better color reproduction, TN usually has higher refresh rate and gtg response time. If you game competetively, get TN 144hz, if not, IPS.
My Rig: AMD Ryzen 5800x3D | Scythe Fuma 2 | RX6600XT Red Devil | B550M Steel Legend | Fury Renegade 32GB 3600MTs | 980 Pro Gen4 - RAID0 - Kingston A400 480GB x2 RAID1 - Seagate Barracuda 1TB x2 | Fractal Design Integra M 650W | InWin 103 | Mic. - SM57 | Headphones - Sony MDR-1A | Keyboard - Roccat Vulcan 100 AIMO | Mouse - Steelseries Rival 310 | Monitor - Dell S3422DWG
https://linustechtips.com/topic/415457-ips-vs-led-monitors/#findComment-5589125
