Need some help with buying rgb leds
ryanwilc
i want to get some leds but i dont know much about them. I am currently looking at these http://www.amazon.com/gp/product/B006K0JYD8?ref_=cm_cd_al_qh_dp_t  are these good?
what else would i need if i wanted to cut the roll in half and use them in two different rooms?
I don't think you can cut them, they are all one long strip, buy 2 shorter ones if you want to do that:
http://www.amazon.com/Bessky%C2%AE-5050SMD-300LED-Waterproof-Flexible/dp/B00ZCNIFEI/ref=sr_1_9?s=electronics&ie=UTF8&qid=1437846734&sr=1-9&keywords=led+rgb
16.4FT = 5M.
Two of the kits you linked would be 10M of LEDs for the same price.
@ryguy.j.wilcox@gmail.com Those kits can be cut just fine. Just cut every 3 LEDs so that there's a power patch for soldering wires and stuff.
16.4FT = 5M.
lol I live in merica
