THIS IS WHAT THE COMPANY SENT AFTER I PICKED THE PARTS SO THIS IS THE HOLE THING :D
Video Card: Nvidia GeForce GTX960 2GB
Processor CPU: Intel i7 4790 3.60 Ghz 4 Cores
CPU Cooling: Zalman x5 Performance Cooler
Memory: 8GB DDR3 1600Mhz Crucial [8GBx1]
Motherboard: Asus Z97-P
Hard Disk 1: 1 Terabyte Seagate HDD
Optical Drive 1: Asus 24X DVD Rewriter
Sound Card: 7.1 Chanel OnBoard Sound
Power Supply: FSP 600 Watt A/PFC 80+ SILVER
Office Software: Open Office Suite PreInstalled
AntiVirus Software: AVG AntiVirus Free Edition
Warranty Period: 3 Year Warranty with Collect & Return
https://linustechtips.com/topic/415079-okay-i-made-it-d/
i7 and a 960? :huh:
CPU: AMD 7800X3D Motherboard: NZXT B650E RAM: 32GB 5600 30-CL Corsair Vengeance DDR5 GPU: MSI Gaming X Trio RTX 2070 PSU: Corsair RM850i Monitor: Samsung 27" 4K thing Cooling:Noctua Chromax Black NH-D15: Case: NZXT H510 Black
https://linustechtips.com/topic/415079-okay-i-made-it-d/#findComment-5584539
Neat, what is the build for?
I am the last guy that should be commenting on this, but you mean whole not hole.
and no gpu? shitposting as its finest
It says 960
why z97 mobo but non k cpu?
It does seem unnecessary especially given that there is no room to upgrade (technically you can but there is no point) where you might put in a k cpu later.
i7 and a 960?  :huh:
Depends on what the build is for, but I think your preconception will end up being correct.
https://linustechtips.com/topic/415079-okay-i-made-it-d/#findComment-5584544
i7 cpu and 960.
https://linustechtips.com/topic/415079-okay-i-made-it-d/#findComment-5584552
Options for SLi with a Z97 board.
https://linustechtips.com/topic/415079-okay-i-made-it-d/#findComment-5584614
It says 960
sry did not see the gpu,but getting z97 and non k its stupid,better an i5
https://linustechtips.com/topic/415079-okay-i-made-it-d/#findComment-5584621
you can also sli with h97,even b85
You can't. SLi requires two slots running at least 8x. The H97 and B85 boards don't have that. They have a 16x and a 4x slot.
https://linustechtips.com/topic/415079-okay-i-made-it-d/#findComment-5584653
