I'm planning a build with these two cases in mind but i can't seem to pick the one that would suit my need and all. The R5 is slightly more expensive from where i'm from and the enthoo pro is a little too big in my opinion, so I just wanna ask on your guys' opinions regarding these two cases and on what I should choose. Thanks
https://linustechtips.com/topic/414996-define-r5-vs-enthoo-pro/
An R4 if it's cheaper.
https://linustechtips.com/topic/414996-define-r5-vs-enthoo-pro/#findComment-5583483
Ironically, the r4 is about 20 bucks more and got me like "whut?!"
Well darn.
Define R5 is a solid case. What about the Define S to save some money?
https://linustechtips.com/topic/414996-define-r5-vs-enthoo-pro/#findComment-5583529
Well...I don't know. The Define S looks solid but it just doesnt appeal to me. lol
It's literally a Define R5 with fewer drive cages.....?
https://linustechtips.com/topic/414996-define-r5-vs-enthoo-pro/#findComment-5583561
Personally, I would go for the R5 just based on looks. ^ - ^
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
https://linustechtips.com/topic/414996-define-r5-vs-enthoo-pro/#findComment-5583562
But... it's just a metal box with a brushed aluminium front?
What a box.
https://linustechtips.com/topic/414996-define-r5-vs-enthoo-pro/#findComment-5583606
If you say that.....then why not take a look at a 750D.
You can always buy more drive cages to add more drives.
It makes my budget over man. It's not as cheap as these two...granted that the 750d is about 30 bucks more, still it's alot to me.
Edit: make that 40 bucks more. just checked its price. lol
https://linustechtips.com/topic/414996-define-r5-vs-enthoo-pro/#findComment-5583643
If you check around sales and stuff, you can sometimes find a 750D cheaper than a 450D.
Looked at prices each day for the 750D to be cheaper than the 450D.......and finally it did.
https://linustechtips.com/topic/414996-define-r5-vs-enthoo-pro/#findComment-5583668
Define r5 is my choice.
CPU: i7 5820k @4.4GHz | MoboMSI MPower X99A | RAM: 16GB DDR4 Quad Channel Corsair LP | GPU: EVGA 1080 FTW Case: Define R5 Black Window | OS: Win 10 Pro
Storage: SanDisk Ultra II 960GB 2x WD Red 4TB | PSU: EVGA 750W G2 | Display:Acer XF270HU + Dell U2515H | Cooling: Phanteks PH-TC14PE
Keyboard: Ducky One  TKL Browns | Mouse: Steel Series Rival 300 | Sound: DT990s
https://linustechtips.com/topic/414996-define-r5-vs-enthoo-pro/#findComment-5584292
Throwing the lone vote for the Enthoo Pro... since I just got one myself.  :lol:
Current Rig: i5 3570K @ 4.2 GHz, Corsair H100i, Asus Maximus V Gene, Asus GTX 970 Turbo, Patriot Viper Black Mamba 8 GB DDR-3 1600 (2x4GB), Sandisk 120 GB SSD + Seagate 500 GB HDD + WD Blue 1 TB HDD, XFX 750W Black Edition, Corsair 350D - https://ca.pcpartpicker.com/b/cbxrxr
https://linustechtips.com/topic/414996-define-r5-vs-enthoo-pro/#findComment-5585490
