Hey guys I have an SilverStone Raven RVZ01 and I can't decide which GTX 960 I want to put in there. My main concerns are Sound Level, Temperatures, & 6-Pin position for easiest installation. I'm a total EVGA fan, but they do not have a "Blower Style" GTX 960, but they do have an awesome ITX 960 that would probably be more quiet (any thoughts?) (Also would mean that I could use the extra fan slot for another fan to control temps?). Other than that I did find two blower style cards (which I hear are better for ITX cases from MSI & Asus anything I should know to help me make a final decision? No OC will be preformed & no other graphic card suggestions outside of GTX 960.
https://linustechtips.com/topic/414940-gtx-960-for-itx/
An ACX cooler in that specific case would be very quiet and do just fine.
https://linustechtips.com/topic/414940-gtx-960-for-itx/#findComment-5582914
If so, then would there be any benefit or damage between going with a ITX single ACX Fan or a Double ACX fan?
Blower cards for that case! The ACX card exhausts into the case, you want a blower card!
The case is made for blower cards. I would suggest the ASUS one or reference card.
5800X3D - RTX 4070 - 2K @ 165Hz
https://linustechtips.com/topic/414940-gtx-960-for-itx/#findComment-5582978
