Why do people buy 960's get a 280x, Better proformence for the money
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
https://linustechtips.com/topic/414752-graphic-card-sli-help/#findComment-5580301
If you were to use cards with different Vram in SLI it would work but only 2GB would be usable but you shouldn't go for low end SLIs one stronger card is always better than two significantly weaker cards when upgrading also I would rather get the 380 or 280X instead of the 960
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/414752-graphic-card-sli-help/#findComment-5580303
Because its not all about raw performance, most people that I know buy Nvidia for features.
https://linustechtips.com/topic/414752-graphic-card-sli-help/#findComment-5580311
False.
I'm not 100% I thought you SLI if they're the same card but if they have different Vram then only the lowest Vram could be used or do they not work at all?
        Setup
https://linustechtips.com/topic/414752-graphic-card-sli-help/#findComment-5580328
Heyyo,
@comcast , welcome to the forums and all that... but please, change your username. :P
As for the answer? You need two GPUs of the same VRAM count. There is hacks to neuter the GPU with more VRAM down to a lower one, I believe it's through BIOS flashing but flashing the BIOS on a GPU is less stable than a motherboard and you run the risk of frying the card if the flash fails and you reboot the system.
Heyyo,
My PC Build: https://pcpartpicker.com/b/sNPscf
My Android Phone: Exodus Android on my OnePlus One 64bit in Sandstone Black in a Ringke Fusion clear & slim protective case
https://linustechtips.com/topic/414752-graphic-card-sli-help/#findComment-5580392
That AMD with crossfire.
Thanks for clearing that up
        Setup
https://linustechtips.com/topic/414752-graphic-card-sli-help/#findComment-5580834
Heyyo,
Thanks for the info, how could I change my username?
https://linustechtips.com/topic/414752-graphic-card-sli-help/#findComment-5581037
Heyyo,
Hmm, tbh I'm not sure how or if it's allowed on LTT... but you can try asking a moderator. The Forum's Code of Conduct says any questions to ask slick
http://linustechtips.com/main/user/15975-slick/
http://linustechtips.com/main/index.php?app=forums&module=extras&section=stats&do=leaders
Heyyo,
https://linustechtips.com/topic/414752-graphic-card-sli-help/#findComment-5581926
