Hi, I have just noticed that one of the CPU temperatures on Open Hardware Monitor says that my CPU is at 125 degrees, however there is another set of CPU temperatures being displayed which are around 30 degrees instead.
Do I just ignore the first set of temperatures near the top, or is there a way to change this? (the top temperatures stay the same when I turn off a couple of the fans or change their speed)
post-71096-0-97456600-1437732372_thumb.p
https://linustechtips.com/topic/414330-cpu-overheating/
try using real temp, if its the same then try reapplying your thermal paste
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/414330-cpu-overheating/#findComment-5574756
It's probably high, try another monitoring software.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/414330-cpu-overheating/#findComment-5574759
