Can Fiio E07K work as both an AMP and a DAC for Ipod Classic?
Solved by ShearMe,
There is no way to connect a DAC to early gen Apple products. You can bypass the internal amp using the L9 adapter, but that's the best you can do.
Yes you can, the cable connect to the dock of the iPod and bypassed its dac.
No, the L9 cable outputs a line out signal, not a digital connection.
Featured Topics
Joseph_Stalin ·
Posted in General Discussion3 -
Evan37 ·
Posted in New Builds and Planning5 -
IlanMS ·
Posted in Peripherals9 -
Frossty ·
Posted in Graphics Cards9 -
StephenB95 ·
Posted in Displays3 -
5
Foxique ·
Posted in Networking2
