Hello users,
So this is my first PC build ever, so any feedback is appreciated! I may or may not change the name of build later.
1. Budget & Location
My Original budget was $1000, but I needed some more power :), Location is Canada/ $CAD.
2. Aim
My aim with this system is to create a gaming pc that is upgradable flexible and budget friendly (I Guess).
Games that I want to run at 1080p 60hz 30fps+ are GTA 5, Project Cars, Arma 3 (Maybe), Minecraft with shaders (Sigh),
Far Cry 4, Battlefield 4 and alot more new releases that my system can run.
3. Monitors
I would plan to get 1 1080p 60hz monitor, if I needed to run two monitors I would upgrade my graphics card.
4. Peripherals
Taken care of. (Just need monitor :P ).
5. Why are you upgrading?
Im not, first build :) .
PCPartPicker part list: http://ca.pcpartpicker.com/p/xqJt23
Price breakdown by merchant: http://ca.pcpartpicker.com/p/xqJt23/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($309.00 @ Canada Computers)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($37.99 @ Canada Computers)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($169.99)
Memory: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1600 Memory  ($63.99 @ Canada Computers)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($63.99 @ Canada Computers)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($66.99 @ Canada Computers)
Case: Antec One ATX Mid Tower Case  ($59.99)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($79.99 @ Canada Computers)
Other: Sapphire Radeon NITRO R9 380 4GB GDDR5 ($309.00)
Total: $1160.93
Generated by PCPartPicker 2015-07-23 01:24 EDT-0400
Srry for all bold text, it wasnt letting me switch back :( .
Edit: Im not all noob, still learning!
https://linustechtips.com/topic/413473-project-zippy_-plans-feedback/
Looks fine to me, I'd personally spend a little more on a better PSU like a EVGA GS or G2 series and spend the little extra on a crucial bx100 SSD rather then the Kingston.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
Get a different SSD, NOW! the V300 is crap
^--- Get a Crucial, Sandisk, Corsair, OCZ or Samsung SSD instead
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
For monitor i use the rl2455hm benq its 60 hz and 1ms delay, i love it but the drawbacks are that the viewing angles are not the best but i think its a really good monitor. for the case don't you think that is a bit bland? or you are going for the non gaming look? if not try the phantom 240
For the case, I might change it to a Fractal Design Core 2500, since its on sale at my nearest store for 55$
Edit: Yeah im kinda going for that non-gaming simplistic look.
Hows this SSD: AMD Radeon SSD 2.5" 120GB
Max Sequential Read 550 MB/s Max Sequential Write 470 MB/s
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($286.50 @ shopRBC)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($69.99 @ Newegg Canada)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($124.48 @ DirectCanada)
Memory: Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory  ($50.46 @ DirectCanada)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive  ($79.99 @ Memory Express)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 380 4GB SOC Video Card  ($279.99 @ NCIX)
Case: Corsair 200R ATX Mid Tower Case  ($79.71 @ DirectCanada)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($89.99 @ Memory Express)
Total: $1121.06
Generated by PCPartPicker 2015-07-23 02:29 EDT-0400
BigDay
Samsung is kinda out of my price range, but is the AMD one any good or better than kingston??, because its a good price!
Go for it! Get any SSD that you can afford but check the reviews first to check if it is reliable, efficient and worth the money (Unlike the Kingston SSDNow which makes use of low quality materials which affects performance and longevity).
Echelon Mk 2.11
