one of my family members are looking for a decent system to play GTAV NBA2k and modern titles.
He wants it to be water cooled and mini Itx a case that is less then 15x15 I was thinking enthoo evolv but budget is an issue so. I also told him that the only way to water cool the system for 700 is to go with an amd CPU and I also told him that he would be better off air cooling and going with an I5. so what I need is an amd and a Intel build that cost less then $700.00
https://linustechtips.com/topic/412359-i-need-a-70000-build/
1. No Water cooling Sub $1000
2. No Fancy ITX sub $900
Buy this and be happy it runs games while using Intel and Nvidia.
Motherboard: Gigabyte GA-H97M-HD3 Micro ATX LGA1150 Motherboard  ($76.98 @ Newegg)
Memory: A-Data XPG V1.0 8GB (2 x 4GB) DDR3-1600 Memory  ($42.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 960 2GB Video Card  ($212.98 @ Newegg)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($44.99 @ Newegg)
Total: $693.93
Generated by PCPartPicker 2015-07-21 15:58 EDT-0400
ZerueLX11
Check me out! LTT Forum Profile!
https://linustechtips.com/topic/412359-i-need-a-70000-build/#findComment-5549570
I did my best in coming up with a build,
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($64.98 @ NCIX US)
CPU Cooler: Corsair H55 57.0 CFM Liquid CPU Cooler  ($53.99 @ Newegg)
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard  ($65.98 @ Newegg)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory  ($54.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($71.89 @ OutletPC)
Video Card: EVGA GeForce GTX 960 4GB SuperSC ACX 2.0+ Video Card  ($209.99 @ Newegg)
Case: Fractal Design Node 304 Mini ITX Tower Case  ($59.99 @ Newegg)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ NCIX US)
Total: $641.80
Generated by PCPartPicker 2015-07-21 16:00 EDT-0400
Normally I say by 2015 you should have a quad core cpu, but given the budget and size requests i went with a Pentium G3258 which a lot of people like and say overclocks like a beast.
As for the case, I don't remember which youtuber it was. I'm sure it was either linus or this one dude awesomesauce but one of them did a build with the case and was able to fit a single radiator.
motherboard has built in wifi adapter, and i chose 8gb of ram. Through in a 2tb hdd which wasn't too expensive.
For the size and performance i think the 960 w/4gb is the better choice. Some might recommend AMD gpus since they're cheaper, but I find that they run a lot hotter which isn't very good for a small build.
Also went with a fully modular psu since it's a small case.
https://linustechtips.com/topic/412359-i-need-a-70000-build/#findComment-5549616
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.95 @ SuperBiiz)
Motherboard: MSI H97M-E35 Micro ATX LGA1150 Motherboard  ($65.98 @ Newegg)
Memory: Corsair Vengeance LP 8GB (1 x 8GB) DDR3-1600 Memory  ($57.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.49 @ OutletPC)
Video Card: MSI Radeon R9 380 2GB Video Card  ($199.98 @ SuperBiiz)
Case: Fractal Design Define Mini MicroATX Mini Tower Case  ($69.99 @ Newegg)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($63.99 @ SuperBiiz)
Total: $687.37
Generated by PCPartPicker 2015-07-21 16:25 EDT-0400
Case size (WxHxD): 210 x 395 x 490mm - 8.2" x 15.5" x 19.3"
EDIT:
Revised the build. This is the one. It has everything except the water cooling, which it doesn't need.
It has built in wifi, the case they wanted, the i5 which is amazing, and the new r9 380 which out performs the 960 for the same price.
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard  ($85.98 @ Newegg)
Case: Phanteks Enthoo EVOLV ITX Mini ITX Tower Case  ($61.99 @ NCIX US)
Total: $699.37
Generated by PCPartPicker 2015-07-21 16:38 EDT-0400
7800X3D - MSI B650 MAG Tomahawk - 32GB 6000mhz CL30 - Gigabyte 3080 TI - 2TB NVME - 1000w PSU - ID Cooling 240mm AIO
https://linustechtips.com/topic/412359-i-need-a-70000-build/#findComment-5549809
This case is ugly IMO, but is cheap
You could get an AIO, i wouldn't
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive  ($44.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 960 2GB Video Card  ($194.99 @ B&H)
Total: $624.78
Generated by PCPartPicker 2015-07-21 16:33 EDT-0400
https://linustechtips.com/topic/412359-i-need-a-70000-build/#findComment-5549897
Total: $687.37
I think the 960 w/4gb is better than the R9 380. the 960 has higher benchmark scores, and is only around 20+ more expensive. Also it has 4gb ram instead of 2gb
https://linustechtips.com/topic/412359-i-need-a-70000-build/#findComment-5549906
You could also do this and get no SSD, gtx 970 will handle
Video Card: Gigabyte GeForce GTX 970 4GB Video Card  ($298.99 @ Newegg)
Total: $683.79
https://linustechtips.com/topic/412359-i-need-a-70000-build/#findComment-5549944
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor  ($214.99 @ SuperBiiz)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($64.99 @ SuperBiiz)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: EVGA GeForce GTX 960 4GB SuperSC ACX 2.0+ Video Card  ($229.99 @ Newegg)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  ($29.99 @ Newegg)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($44.99 @ NCIX US)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($14.98 @ OutletPC)
Total: $691.81
Generated by PCPartPicker 2015-07-21 16:44 EDT-0400
no over clocking here.
I included a Optical Disc because i dunno weather your friend will go Disk or Download.
That being said, I didnt but a ssd becaues i put in a stronger cpu.
I was also planning on a radeon card .. but the psu mightve not been able to handle it.
I am a ... NVIDIA FANBOY!
https://linustechtips.com/topic/412359-i-need-a-70000-build/#findComment-5550005
Total: $683.79
that psu ... its dangerous to use according to this community LOLZ
https://linustechtips.com/topic/412359-i-need-a-70000-build/#findComment-5550021
Do more research.
https://linustechtips.com/topic/412359-i-need-a-70000-build/#findComment-5550030
Do more research.
my sources say otherwise. Also 960 is more energy efficient than 380, and isn't as hot.
https://linustechtips.com/topic/412359-i-need-a-70000-build/#findComment-5550048
Total: $687.37
EDIT:
Total: $699.37
I think this looks like a good option only im going to get 2x4gb sticks of DDR3  and a cheaper PSU and Just give him the 1tb 2.5 inch drive out of my pc and set him up with a 370 and change the board to a gigabyte board.
https://linustechtips.com/topic/412359-i-need-a-70000-build/#findComment-5550435
