Maximum Amps/Voltage Supported on 4 Pin CPU Fan Header
Solved by d1screet,
I'd imagine it would vary greatly from motherboard to motherboard. Why not just invest in a Molex to 4-pin splitter with PWM support? You can draw power straight from the PSU while still maintaining PWM support for RPM readings and fan controls.
Share
Followers
3
