Push/Pull with fans?
Go to solution Solved by W-L,
Hey guys! My RAM is too high profile, so it blocks the use of my dual 120 mm fans. So instead of setting my fans to "push" from the inside, can I mount my fans on the outside of my case and set them to pull?
Yeah you can mount it on the outside as long as you can get power to them but there isn't much difference in push pull setups maybe a few degrees.
Black and green build, I call it "Murphy". - CPU: Intel i5 4690k at 3.5 GHz - GPU: Gigabyte G1 Gaming GTX 980 Ti - Motherboard: Gigabyte Z97X SOC Force - RAM: 8GB 1866 MHz Corsair Vengeance Pro (gold) - PSU: EVGA SuperNova 750 B2 - Storage: 240GB Corsair Force LE SSD & 1TB Western Digital Black HDD - Case: Corsair Carbide 300r - Lighting: 2 green Logisys LED sticks (currently removed)
https://linustechtips.com/topic/411084-pushpull-with-fans/
https://linustechtips.com/topic/411084-pushpull-with-fans/#findComment-5533742
Okay, thanks! :D
https://linustechtips.com/topic/411084-pushpull-with-fans/#findComment-5533750
