Hello all!
           I'm here today because lately my computer is having BSOD issues, and I'm having trouble diagnosing it. I've had the system since 2009, upgraded the CPU, GPU, and PSU in 2011, and was running fine until the last few weeks of June and continues to now.
Prior to resetting to factory defaults, I would get 0x124 errors with the occasional 0x3b, or 0x1e. I couldn't watch Youtube or play Factorio/Skyrim for more than a few minutes before crashing. Sometimes I would leave the computer on, go to work, and come back and see it turned off. After a few weeks of failing to figure it out, I opted to reset.
After resetting, I can watch Youtube and play Factorio for days straight if I wish. When it comes to skyrim however, the PC will still crash after playing for a while. Though now I can play it a little bit longer.
By the way, Factorio is a early access game (not on steam, has its own site) that uses sprites. I figured I would include that info if it helps at all in troubleshooting.
Thank you!
Hydra
  • Vista x64 Home Premium - OEM (It's the original OS that came with system)
  • Most of the hardware is 6 years old. With the exception of the GPU, CPU, and PSU, which are 4 years old.
  • I have re-installed the OS via the recovery option.
  • AMD Phenom II X4 980 Black Edition Deneb Quad-Core 3.7GHz Socket AM3 125W HDZ980FBGMBOX
  • EVGA 01G-P3-1450-RX GeForce GTS 450 (Fermi) 1GB 128-Bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card *NOTE: REFURBISHED*
  • MS-7548 (Aspen)
  • CORSAIR CX series CX600 600W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
  • HP Desktop PC Pavilion A6745F(FQ570AA)
Dropbox links for:
PERFMON file
Sysnative file
DMP files
https://linustechtips.com/topic/410932-bsod-issue/
Install the latest drivers? (if they do have them for Vista)
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
https://linustechtips.com/topic/410932-bsod-issue/#findComment-5534421
Instead of using the recovery media, you should use an ISO to clean install, then use the key that came with the system (I assume it was pre-built except for the upgraded parts)
CPU Intel i7-4770k @4.4Ghz Motherboard ASUS Maximus VI Hero RAM Corsair Dominator Platinum 1866Mhz 16GB GPU MSI GTX 970 GAMING 4G Case Corsair 760T Storage Samsung 840 EVO 250 GB + 2x WD Black 1TB PSU Corsair AX860 Display(s) AcerXB1, QNIX QX2710                         Cooling Corsair H105 Keyboard Corsair K70 Cherry MX Red + Red LED Mouse Logitech G700s Sound Beyerdynamic MMX300
https://linustechtips.com/topic/410932-bsod-issue/#findComment-5534450
That was the first thing I did, before and after the reset. Still get the 0x124 code.
*Edit*
Thinking about it, I'm not entirely sure if I did get all of the drivers.
Is there a trustworthy program/website to scan the PC and have updated to download?
https://linustechtips.com/topic/410932-bsod-issue/#findComment-5534678
I'm afraid of formatting that recovery partition in case HP pulls support for my system. It's bad enough that AMD no longer has drivers for my CPU. Which could very well be the problem. Doing a quick google on how to do a bootable USB for vista, it looks a little complicated. If I manage to screw it up, I won't have that partition as a safety net. I would also need to buy a thumb drive. I rather not spend any more money on this system, as I want to save up for a new one for the upcoming Fallout 4.
Thanks for the suggestion though!
https://linustechtips.com/topic/410932-bsod-issue/#findComment-5544102
I also downloaded a driver program called DriverMax. Says I have a bunch of outdated drivers and I've been installing them. Slowly though since the free version caps the downloads to 2 per day.
While I slowly see if these updates work, anyone else have a theory?
https://linustechtips.com/topic/410932-bsod-issue/#findComment-5544110
