Hi Guys
I'm new here and new to building gaming rigs. I have exactly $1100.
I plan to use the following:
http://pcpartpicker.com/p/GTsHTW
This would be the first time I would build a pc, I was hoping for any tips or things to change from my build.
I have a 1080p monitor, so I'm gaming on that one. I plan to play The Witcher 2 and 3, Dragon Age Inquisition, and probably Crysis 3 just for the heck of it.
I already have a gaming mouse and keyboard so I'm good on that one.
Thanks much :)
https://linustechtips.com/topic/410190-first-ever-build-~1000/
Looks okay, but you need a better power supply. Get a EVGA 500B 80+ bronze.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/410190-first-ever-build-~1000/#findComment-5523835
Looks good, but why not go for the i5 4690k rather than the 4590? Or the 4690 if you have no intention to OC.
CPU: AMD 7800X3D Motherboard: NZXT B650E RAM: 32GB 5600 30-CL Corsair Vengeance DDR5 GPU: MSI Gaming X Trio RTX 2070 PSU: Corsair RM850i Monitor: Samsung 27" 4K thing Cooling:Noctua Chromax Black NH-D15: Case: NZXT H510 Black
https://linustechtips.com/topic/410190-first-ever-build-~1000/#findComment-5523838
Pretty good but you should probably at least get a semi modular PSU because that case doesn't have good clean cable management and for the price to ratio of a 980 there's not much point in buying it I would go for a 390/970 or 390X
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/410190-first-ever-build-~1000/#findComment-5523906
Hi Guys
Thanks much :)
Here you go! All high quality and excellent parts :)
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($189.99 @ NCIX US)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($69.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($97.95 @ OutletPC)
Video Card: Gigabyte Radeon R9 390X 8GB SOC Video Card  ($434.99 @ NCIX US)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Newegg)
Total: $1086.66
Generated by PCPartPicker 2015-07-18 14:55 EDT-0400
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/410190-first-ever-build-~1000/#findComment-5523928
Total: $1086.66
Thank you this looks good, I plan to buy all my parts in the US in bring it home to the Philippines.
https://linustechtips.com/topic/410190-first-ever-build-~1000/#findComment-5524026
OH MY GOD! I envy you so much  :lol: Thats an EXCELLENT idea since parts are soooo much cheaper in the US (I dont know why is that especially since we are closer to China)! Just make sure you stress test and benchmark each component to make sure they are working before you bring them to the Philippines.  ;) The build I gave you is even color themed so that it will look good through the case and performs like a BAD ASS! Good luck kababayan.  ^_^
Echelon Mk 2.11
https://linustechtips.com/topic/410190-first-ever-build-~1000/#findComment-5524063
I like the inclusion of the 212 evo  :)  I forgot to factor in the Philippine weather, it will probably have better temps in the summer.
https://linustechtips.com/topic/410190-first-ever-build-~1000/#findComment-5524249
Yes, its a cheap CPU cooler that performs as well as other more expensive air and/or water coolers. ^_^
Echelon Mk 2.11
https://linustechtips.com/topic/410190-first-ever-build-~1000/#findComment-5524480
