   okay so the place i work always has these left over large pieces of tempered, safety, and regular glass. normally they dont care if you take some home for whatever you need as long as its from the "scratched" pile. i was wondering would it even be do able to take a bunch of the things and make an all glass case out of it??? id have to somehow cut them into smaller pieces as all are much taller then a full tower or super tower case as is. would an all glass case even work or would the temp difference crack the glass inside? i was thinking just do the standard square sized case, use the hd cases from an old case, maybe cut a mb tray outta an old case or try and make a glass one. then use some of the door hardware we have at work to make the side panels open and close. if anyone had any experience working with glass or has any info on how to build something like that by all means tell me. just think in my opinion it would make a SUPER cool and one of a kind looking case
https://linustechtips.com/topic/409700-crazy-case-idea/
