Multi-platter drive backup
Go to solution Solved by Godlygamer23,
Performing backups within itself isn't really that great. If the spindle or arm motor dies, the hard drive is unusable. You have to spend thousands of dollars just to attempt to get the data back. It's not worth it.
If you partition it. You don't see the drive as 2x1TB platters.
https://linustechtips.com/topic/40812-multi-platter-drive-backup/#findComment-528477
Well, you need enough space on whatever it is you're storing the backup. So as long as the thing is less than %50 full, you could probably try and put it there  :P. What a bad idea though, defeats the purpose of a backup.
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/40812-multi-platter-drive-backup/#findComment-528483
https://linustechtips.com/topic/40812-multi-platter-drive-backup/#findComment-528487
Would an HDD with one failed platter still read? I would assume that failure of the more intricate moving parts would be more likely?
If you got it read professionally, yes. But if the spindle dies, both platters are unusable, and if the platter got scratched, the magnetic film gets scraped off - thereby making that spot ineffective.
https://linustechtips.com/topic/40812-multi-platter-drive-backup/#findComment-528530
