The more radiator space dissipates heat faster, so obviously the deepcool 240, may I ask why you are not open to suggestions of other AIO coolers?
Asetek is the OEM, so usually anything coming from others is an improvement. The Asetek one seems pretty outdated which probably means a loud pump and prone to failure, too.
https://linustechtips.com/topic/407210-which-cooler-for-my-cpu/#findComment-5487474
