so i purchased GRID in the steam sale and when playing i get a really annoying buzzing through my speakers, it changes pitch as i go through the menu, i have updated my audio drivers and this has not solved the issue. The game as stated was purchased through steam so should be up to date. Anybody have any ideas? thanks in advance. Ky
https://linustechtips.com/topic/40657-buzzing-noise-whilst-playing-grid/
Do you only have this problem in GRID? Are you sure your sound cable in plugged in correctly?
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
Sounds like coil whine. Other things in your system are probably effecting your sound card or whatever you have.
it is only happening in GRID, all other games and movies and so on are fine.
Are you using the onboard sound card or a dedicated one?
onboard on this http://uk.asus.com/Motherboards/AMD_AM3Plus/M5A78LMUSB3/
EDIT- just tried a USB to audio adapter i had hanging around and i still have the same issue so it's obviously a problem with the game :(
Hmm.....sorry but I'm out of clues here....maybe try reinstalling it?
Its not harmfull btw tough anoying if seen people use nail polish to fix the whining, but bassicly just limit fps don't let it exceed like 120 fps for example.
During some loading screens for example fps can exceed like 1000 fps thats when it usualy starts to whine.
Well that's the thing it was coming through the speakers not from the pc. Also I just used fraps and it's locking to 60fps so all good, again thanks for the help.
the thing i mentioned comes from gfx card if limiting fps helps.
if its the psu then i think its time for new psu.
mute sound turn of speakers see if still hear it.
Well it's definitely the gpu the psu is about 6 hours old lol
you have to test it to be sure, never heared of doa's ? that can mean damaged on arival to stop trusting new hardware so much they can be bad to.
i'm not that much of a noob lol it was only happening in that game, TR was fine, Assassins creed was fine, so was Gears of War, running Prime 95 it was fine for 6 hours to test the OC stability was fine lol
