Hello, i have bought Seasonic 520W PSU since i was thinking of GTX 960, but after reviews i considered to buy MSI GTX 970, so only one question, shoud i buy new PSU, or this will be ok?
Spec: I5-4690
1 HDD
2 -120mm fans.
Your PSU is going to be fine. 970 is not a super hungry card.
https://linustechtips.com/topic/405933-psu-help/#findComment-5470548
Even Nvidia says 500w is enough. So it's just fine and you may be able to OC them A LITTLE.
Link:
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-970/specifications
Edit: I'd even go that far and say that e decent OC should still be possible with 520W.
PC CPU i7 4770 non K Motherboard Asrock Z97 Extreme 9 RAM 32gb Corsair LP GPU 2x r9 290 Case Phanteks Enthoo Primo Storage 4x2TB WD Black in Raid 0, Samsung 840 EVO 500GB, Samsung 850 EVO 500GB, Samsung 850 PRO 256GB PSU Super Flower Golden Green 1000W Display(s) 3x Asus 24" Full HD Cooling Custom Watercooled, Radiators: 1x 420, 1x 360, 2x 240, 1x120 Keyboard Corsair Vengeance K95 Mouse Mad Catz R.A.T. 7 Notebook Asus UX360UAK (i7 7500U, 8GB Ram, 256GB SSD, 3200x1800 touch, 2 in 1)
https://linustechtips.com/topic/405933-psu-help/#findComment-5470571
Link:http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-970/specifications
The only reason they say 500 watts is because then someone with a FX-9590 and a but load of fans and HDD's is covered by the blanket statement.
https://linustechtips.com/topic/405933-psu-help/#findComment-5470610
