Hey I am going to order one and I just wanted some help finding one as cheap as possible on the least sketch site you can find :P I would do it but I need to do some stuff
  • CPU: AMD Ryzen 2700X
  • Motherboard: MSI X470 Gaming Pro
  • RAM: 32 GB HyperX Fury DDR4 2400
  • GPU: MSI 5700XT MECH
  • Case: Fractal Define R5
  • Storage: 1TB WD Black 7200 RPM HDD, 2TB WD Black 7200 RPM HDD, 4TB WD Black 7200 RPM HDD, Samsung Evo 960 1TB SSD
  • PSU: Corsair CX750M
  • Display(s): HP 24W
  • Cooling: 1 120mm Corsair fan, Noctua NH-U14S
  • Keyboard: Razer Blackwidow 2016
  • Mouse: Razer Deathadder Basilisk.
  • Sound: Razer 7.1 Kraken Chroma V2, LG SJ4Y 300W soundbar
  • Operating System: Windows 10 Professional 64 bit
https://linustechtips.com/topic/405736-help-with-fx-8320/
U also need a motherboard? if so try and go intel
otherwise :
Look on ebay
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468163
otherwise :
Look on ebay
No the only reason I am getting the CPU is because I won a Mobo on a twitch stream :P I'm saving Intel for my $1800 rig :D
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468177
Oh gawd so many replies! US BTW Oshino. The mobo isBioStar HiFi TA970 Plus
Could you give us your location? No point in me giving you a UK site if you're in Australia.
a 125W TDP CPU, you gotta need some good quality motherboard for this one not some cheap one.
Okay, which motherboard specifically did you win on the Twitch stream?
I would also prefer the option for next day shipping! Thanks! :D
Edited by harveychestbreach
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468220
Ebay look for an 8350 or 8320 used/new
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468233
Do you want to overclock?
GAMING RIG:
CPU: i9-14900k
MOBO: Gigabyte Z790 Aorus Elite AX
RAM: 64GB G.Skill Ripjaws S5 @ 6000MHz
GPU: Gigabyte Gaming OC ICE 16GB 9070XT
STORAGE: Crucial 1TB NVME (Boot Drive) / 2TB Crucial NVME / 4TB 990 EVO Pro NVME SSD
CASE: Dimas Tech EasyBench V3.0
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468235
Just enough to get to the same clock speed as the 8350 :3
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468243
Ebay is no no no.
Thats your opinion and your entilted to it. I have purchased 100+ things on ebay and never had a problem even with the used stuff.
I also sell a fair bit on ebay too
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468265
Ebay is no no no.
Lol yeah I know I was starting to consider it because I found one for $86 but I don't want the risk nor do I want the wait
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468267
U will be fine to do that
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468270
Up to u but ebay has never failed me.
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468275
How likely is someone to buy my mobo and processor? The one that is currently in my PC :D
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468280
Budget? I'd go with the Asus M5A99FX PRO R2.0
GAMING RIG:
CPU: i9-14900k
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468285
Depends which one it is but its pretty likely, ppl buy even the weirdest shit on ebay
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468286
Just enough for the CPU thank you :D I have a mobo already Budget: $140-150 prefferably
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468299
I just wanted to say really fast that I appreciate you guys helping me :D (not done yet)
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468302
Lucky you, i got scam $25 when i purchase a 8GB RAM for my mom laptop. After i make a purchased and waited, all i received is A PICTURE OF THE RAM. I was like WTF?! This picture cost $25?! Were i can print this on my .88 cents paper.
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468305
CPU then? Go with a 8350 or try to squeeze a 8370 in there
GAMING RIG:
CPU: i9-14900k
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468306
Lucky you, i got scam $25 when i purchase a 8GB RAM for my mom laptop. After i make a purchased and waiting, all i received is A PICTURE OF THE RAM. I was like WTF?! This picture cost $25?! Were i can print this picture on my .88 cents paper.
lol validate sources man be internet smart :P
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468310
Budget correction $100-150 I did say I wanted as cheap as possible
https://linustechtips.com/topic/405736-help-with-fx-8320/#findComment-5468317
