hello everyone, im planning to install a another monitor, it will not be used for gaming so ill plug it into my motherboard directly, so i need steps on how to do it so i dont mess it up, a question that i have will i need certain specs?
thanks guys for your responds! :D
https://linustechtips.com/topic/40546-need-help-installing-dual-monitors/
So you have a video card? Why not plug it into there?
Just plug it in. ;)
Make sure the onboard video is enabled in the BIOS and you should be good to go.
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
Find another video port, plug it in.  No special procedures needed.  To adjust what is displayed on it (duplicate first display, extend desktop, etc.) hit Windows key + P or right click on your desktop and hit Screen Resolution.
ive been told that it wont affect my FPS if i plug it into to the intergrated graphics
It won't really affect your fps.
Do you already have a dedicated gpu?
What GPU are you using?
If you spend a bit more, you can get the Boost version. Here's ASUS version of the Boost. http://www.newegg.com/Product/Product.aspx?Item=N82E16814121728
And here's the regular version from ASUS. http://www.newegg.com/Product/Product.aspx?Item=N82E16814121686
my current GPU is a EVGA GT 640 2gb, but ill will be upgrading to Asus GTX 650 ti 1gb
Get the 7770 or 7850 instead for much better performance unless you need the cuda cores.
To enable running your second display off your motherboard, go to your bios and enable IGD Multi monitor.
