A good can of air will work wonders for you!
CPU Ryzen 5 Asrock B350 Pro 4 / MSI RX580 Gaming / RAM 16 Gigs Corsair Vengeance 3000 / HDD 1TB Seagate Barracuda / SSD Samsung 840 120GB / 500GB Samsung SSD / Case Urban S31 / PSU EVGA G2 750w / Os Windows 10 / Keyboard Corsair K70 / Mouse Razer Naga 2013 (Won it from Linus!!
https://linustechtips.com/topic/40534-cleaning-a-cpu-fan/#findComment-524805
I usually just get a can of compressed air and blow between the fins and on the fan to remove the dust. I do not replace my thermal compound when I am cleaning it because I do not remove the heatsink off my cpu.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/40534-cleaning-a-cpu-fan/#findComment-524814
The intel stock heatsink can have its fan removed without removing the heatsink.
It's kind of tough to un-clip it from the heatsink, but you should manage.
Use a damp paper towel or cloth to manually remove the dust from the underside of the blades.
The same method can be used on other fan/ heatsinks.
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
https://linustechtips.com/topic/40534-cleaning-a-cpu-fan/#findComment-531633
Use some canned air and spray away. If you can take the fans off first go for it. If its not possible please at least hold the fan blades still.
https://linustechtips.com/topic/40534-cleaning-a-cpu-fan/#findComment-531670
never use a vacuum it can cause static and damage your pc
Yes static it es bad. An air compressor without a filter is just as bad too because of water build up...
https://linustechtips.com/topic/40534-cleaning-a-cpu-fan/#findComment-537453
Unplug pc first before all. If dust is just light, compressed air is enough and you can use vacuum with low power to keep dust from fallin back to case. Just don't get it too close to hardware. If dust is so thick air isn't enough I use soft toilet paper to clean if from fan blades. You can remove fans and blow dust away from heatsink but most of fan is concentrated to fan.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/40534-cleaning-a-cpu-fan/#findComment-538317
take it apart as much as you can and spray with some compressed air(canned air). reapply the thermal paste and re assemble.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/40534-cleaning-a-cpu-fan/#findComment-547217
