Best CPU AIR cooler for my new custom build.
EnSabahNur
Because this forum here always seems to have the very best and knowledgeable community around, I thought I'd post my question to those who know more than myself.
In short, I'm making a new custom rig for a friend in this mini tower linked here: http://www.newegg.com/Product/Product.aspx?Item=N82E16811108457 , and because I'm only installing 1x 980ti I've been told that water cooling won't be necessary, thus I need the very best performing/looking CPU air cooler for the price you can think of that also fits this mini tower at the link above.
I'm not sure which motherboard I'll be purchasing quite yet, but I think I'll be going with the ASRock X99E-ITX/ac at this link: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157588&cm_re=x99_itx-_-13-157-588-_-Product , due it seeming to be the only mother board that supports an i7 5820, DDR4 and will fit in this mini tower.
Overall, I really just need the best performing, best looking, CPU cooler that will fit in this case. If possible, please provide a direct link to your suggestion to ensure that I don't order the wrong model, and thank you so much in advance for your help.
Noctua NH-D15*
CPU: Intel Core i7 5960X @4GHz cooled by a Corsair H110i GT | MBO: Asus X99 Sabertooth | RAM: Crucial Ballistix Sport 32GB DDR4 (4x8GB 2400MHz) | GPU: Gigabyte G1 Gaming GTX 980 | SSD: Samsung SM951 M.2 SSD | HDD: 1TB Western Digital Black Drive | PSU: Corsair HX750i | Case: Corsair Obsidian 450D
If it fits, the Dark Rock Pro 3. SO FRIGGIN SEXEH.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
NH-D15 is the best air cooler but its large and wont fit in all builds, u need low profile RAM
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
Get a Noctua NH-D15, contact Noctua for a narrow server LGA 2011-V3 mount, and paint the thing black see guide here:
He has 130mm clearence for the cooler guys, think low profile.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
I think the best choice for you would be the Dark Rock TF from Be quiet!, tho you may have to change the top fan for an slim one or simply not use it to get the clearence. It's a very sexy cooler and supports a TDP of up to 220W (A bit less if you change the top fan for a slim one) so, lots of overclocking  headroom
http://www.newegg.com/Product/Product.aspx?Item=9SIA68V32N4373&cm_re=DARK_ROCK_TF-_-9SIA68V32N4373-_-Product
The height according to the site is 130,8 mm so its literally less than a milimeter to tall with both fans, i would try and see if it happens to fit and if it doesn't, just removing the top fan or replacing it for a slim one like a sliverstone FN123, tho i think it should cool well enough with a single fan.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
Thx so much for the help. So my last question would be, can both a 980 or 980ti and a CPU cooler fit in my build listed below?:
- I purchased an: ASRock X99E-ITX/ac LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.1 USB 3.0 Mini ITX Intel Motherboard (like suggested) seen here > http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=ASRock+X99E-ITX%2Fac+LGA+2011-v3+Intel+X99+SATA+6Gb%2F&N=-1&isNodeId=1
IN WIN 901 Silver Aluminum / Tempered Glass Mini-I (case) seen here > http://www.newegg.com/Product/Product.aspx?Item=N82E16811108457
-  x2 4gb of DDR4 sticks of RAM
- an EVGA Supernova 850g PSU seen here  > http://www.bestbuy.com/site/evga-supernova-power-supply/5408054.p?id=1219127074534&skuId=5408054&ref=17&loc=10&CampaignID=728069&SubscriberID=13520892
- and will be purchasing a new gtx 980ti or 980 within the next few days
People have done builds with this case and GPU combo, so it should fit just fine, but I want to ask the more experienced community if the CPU cooler that the ASrock motherboard comes with (as you can see in the link) or slim low profile cooler like the Noctua NH-L12 120mm & 92mm SSO Bearing PWM Fans will fit with this setup ok.
It is my assumption that because the CPU cooler that comes with the ASrock mini motherboard, comes with a mini motherboard, it should fit smaller cases just fine; but my main concern is if the CPU cooler, the big GPU, RAM, and PSU I got all fit well in this case?
