The first one is "Technically" better, but you won't notice a difference and on either you would still need a Bios update.
Just remember: Random people on the internet ALWAYS know more than professionals, when someone's lying, AND can predict the future.
i7 9700K (5.2Ghz @1.2V); MSI Z390 Gaming Edge AC; Corsair Vengeance RGB Pro 16GB 3200 CAS 16; H100i RGB Platinum; Samsung 970 Evo 1TB; Samsung 850 Evo 500GB; WD Black 3 TB; Phanteks 350x; Corsair RM19750w.
Laptop: Dell XPS 15 4K 9750H GTX 1650 16GB Ram 256GB SSD
sex hahaha
https://linustechtips.com/topic/404472-which-build-is-better/#findComment-5452914
With the second build you do not need additional wireless adapter, it comes boundled with the ASUS Z87-Pro motherboard
could try to put that money to upgrade to R9 290
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/404472-which-build-is-better/#findComment-5452950
can u explain what the bios update is?
don't bother, you don't need it
https://linustechtips.com/topic/404472-which-build-is-better/#findComment-5452975
Go for an i5-4440 instead, it's $5 cheaper, will perform the same, and definitely will not need a bios update (even though a 4460 probably wouldn't need a bios update either).
A bios update is updating the firmware on the motherboard that allows it to function properly -- and requires a chip that works on the current bios to update it to a new bios. The 81/85/87 chipset is compatible with Haswell CPUs, but require a bios update (which should be preinstalled at the factory) to work with Haswell Refresh CPUs. The i5-4460 is a Haswell Refresh chip while the i5-4440 is a Haswell (non-refresh) chip thus the 4460 could potentially (albeit highly unlikely) need a bios update whereas a 4440 would not.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/404472-which-build-is-better/#findComment-5452993
